Blower motor not working
Discussion in 'Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)' started by nutlug, Jun 25, 2012.
  1. nutlug
    nutlug New Member
    I just picked up a 97' Tahoe and no action out of blower so I tested the two wires. Nothing from the hightest setting, but the lower settings all read 12v about ,so I pulled the motor ,tested it runs good so the 12v. I read won't even lite a small bulb The switch ? Any ideas Thanks, Steve
  2. vncj96
    Blower motor resister, they are usually the culpret. Its hardend wires, it is usually bolted to the truck with a screw or 2, if the hardened wires are rusted or corroded then that could be the problem, they are around 20 bucks to replace.
  3. ChevyBoy2009
    ChevyBoy2009 Rockstar 4 Years 500 Posts
    blower motor resistor:great:
  4. nutlug
    nutlug New Member
    replaced the resister, still nothing
    Ok , So I pull the resister (what a pain) looked ok but I went and got a new one and still no action from blower. Do the speed control switchs ever fail ? Any thoughts? Thanks, Steve
  5. kw70chevy
    kw70chevy Member
    the fan switch does go bad.
  6. nutlug
    nutlug New Member
    Ok, So I pulled the switch and that was it. If you look real close at the terminals the plastic is a little melted next them, $39 bucks to the dealer and it's good to go . Thanks, Steve
  7. Steelhead
    Steelhead New Member
    I replaced my resistor a few months ago, and the replacement has failed already. The cuicuit board on the resistor had a burn mark on it like the last one. What should I look for now.
  8. kw70chevy
    kw70chevy Member
    the blower motor may be pulling to many amps
  9. Steelhead
    How do I fix that?
