Blowing Fuel Pump Fuse
Discussion in 'Performance & Fuel' started by wmc3, Jan 24, 2012.
  1. wmc3
    wmc3 New Member
    Hello all, I have an 08 silverado 1500, ext cab 5.3L. Got up this lovely cold NY morning, tried to start mt truck and noticed the lack of the fuel pump sound......checked the fuel pump fuse and noticed it was blown. I replaced the 20 amp fuse and it popped instantly. ANY help I can get is much appreciated, since it is about 25 degrees and my truck sits in the driveway!!!
  2. SurrealOne
    Welcome! You might try posting in the appropriate technical area of these forums as that'll get more eyes on your issue.
  3. wmc3
    wmc3 New Member
    Thnx, new to all of these forums, I will look around for the right place.....
  4. 99'HEARTBEAT
    ***thread moved***
  5. mfleetwood
    Welcome to the Club!! Sorry, but I do not know the answer to your question, but I am sure someone here will be able to help.
    Good luck!
    ---------- Post added at 05:22 PM ---------- Previous post was at 05:21 PM ----------
    Thanks Mike!!
  6. wmc3
    wmc3 New Member
    Thanks Mike
  7. 99'HEARTBEAT
    Your Welcome.....We all were new member's once......no harm, no foul.......:glasses:
  8. mfleetwood
    X2 wmc3. There are a lot of sections to this forum and it is not always easy to find the exact right place for everything, especially if your new.
    We're glad your here! .....I'm sure you'll find some help shortly.
  9. sstoner911
    Check your o2 sensors and the wiring to them. If the wiring is crack or exposed it will cause that exact issue. If all that looks good there is another wire issue somewhere.
  10. Red Z71 Max
    It is possibly The O2 sensor but if that doesn't fix it you may have a bad fuel pump.
