Body filler? Need to safety!
Discussion in 'Chevy Truck Accessories' started by 86s10, Jul 23, 2009.
  1. 86s10
    86s10 New Member
    hey guys
    i have my 86 chevy s10 im working on
    been doing lots of body work lately with grinding down sanding bondo sanding again and using primer soon to paint.
    although i have a decent sized rust hole on the rear fender, i have already cut it out better and grinded the rust away.. i cant get behind it so ive been confused on how to fill it. i thought up of doing this, pretty ghetto but apparently works.
    you use expanding spray foam, spray it in so it expands out of the hole. then cut the excess away with exacto knife, then bondo over top of it to smooth it out and then primer it.
    any other ideas that dont invilve welding and can be done without getting behind the hole?
    ive heard of fiberglass but i think i would need to get behind it.
    or even cutting out screen from a window screen, adhereing it, then bondo?
    any suggestions are great. thanks!!
    need to safety this thing!!!
  2. EvilNetwork
    EvilNetwork Rockstar
    The best way to do this with limited tools:
    Sheet Metal
    Pop Rivets
    Body Hammer
    Cut a patch that extnds beyidn the size of the hole a few inches. Put patch behind hole, pop rivet. Using body hammer, slightly dent the areas you pop riveted. Grind off the rivet heads and fill with a little tiger hair first. Once hardened, grind off rough spots and fill with body filler.
