bose speaker swap
Discussion in 'Audio, Video & Gadget Tech' started by 2000 silvy, Feb 16, 2010.
  1. 2000 silvy
    2000 silvy New Member
    i'm new here but i was wanting to swap out my factory door speakers for some factory bose ones they sound alot bettr to me so the question is is it just the speaker thats the difference or do you have to swap the whole door panel over my trucks a single cab so what factory ones will it swap over with? thanks
  2. TritonBoulder47
    The speakers are the same size and have the same plugs... It's just a simple swap out...
  3. ajarman
    I would think the factory amp or head unit would need to be replaced to push the bose speakers.
  4. TritonBoulder47
    Not really... There isnt much difference between the factory delco GM speakeres and the Delco Bose speakers... They are both paper cone with foam surround...
  5. 2000 silvy
    thanks for the info i have a aftermarket deck (guess i shoulda mentioned that) the bose sounded alot cleaner when i've heard em bone stock and my deck overpowers the speakers and they justy rattle alot and sound like garbage quiet theyre good but i just want to be able to turn it up the odd time and have it not sound like my speakers are gonna blow up next check i'm gonna get a pair is it hard to swap? or just a few screws and plug in the bose ones?
  6. TritonBoulder47
    Four screws and 1 plug on each speaker, simple swap...
    But in my opinion, I'd change your speakers to an aftermarket set... putting another set of stock speakers (be they Bose or GM Delco) will not give you the clearity and precision that you're looking for... Even a cheap set of 6.5's from Wal*Mart will be better then stock... LoL
  7. 2000 silvy
    k ya i'll probably do that then instead i just heard a set of bose ones and i thought they sounded pretty good but walmart ones are probably cheaper too lol i'm gueesin they should just plug in as well or do i have to change anything? thanks
  8. TritonBoulder47
    With any aftermarket speaker you will need a wiring adapter... You can get them from Crutchfield, Best Buy, or your local install shop... But if you order your speakers from Crutchfield, you'll get them for free...
    But if you dont want to do that, there is an easy trick for getting the polarity correct when you replace your speakers... If it's not labeled on the speaker itself (some do, GM usually does not... LoL), cut the wires off the plug leaving about 1-1.5 inches. Strip the sheilding off of the wire attatched to the plug. Now with the plug attatched to the speaker, take a 9 volt battery and touch the 2 contacts on the battery to the 2 wire leads you have from the plug. If the speaker gets "sucked in" then the polatiry is backwards. If the speaker gets "pushed out" then you have the correct polarity. Write down what speaker is positive and what speaker is negative for that door. If I remember correctly, each door has a different color set of wires...
  9. 2000 silvy
    thanks for the info so then i wont have to buy an adapter then? or do i still need the adapter?
  10. TritonBoulder47
    You wont need the adapter if you use the methoid I described to test the polatiry...
