    Join Today ~ It's Free
both low beams out at the same time?
Discussion in 'GM Electrical Tech' started by quicksilver8817, Feb 7, 2011.
  1. quicksilver8817
    quicksilver8817 New Member 100 Posts
    i cant find a fuse and the bulbs seem to be okay . the highs still work. is there a relay?
  2. TritonBoulder47
    TritonBoulder47 New Member 100 Posts
    What year truck...? There should be a relay and a fuse for each set of lights. It's in the under hood fuse panel...
  3. murdog94
    murdog94 New Member 1000 Posts 100 Posts
    Yep more on the year, since i have had the multifunction switch act funny, and when you go to high beams it will stick, and when you try to switch back to lows they wont come on. Also the head light switch. But as mentioned start with relays etc.
  4. quicksilver8817
    well its a 1990 k 1500 . uhm i cant seem to find a fuse . last night the low beams came back on . i have a spare headlight switch and it had no effect . so idk what it is unless there is a relay but i dont know where its located .
  5. murdog94
    There isnt a relay.. it sounds like your Multifunction is shot.
  6. quicksilver8817
    idk the weird thing is my plow lights are wired with my low beams. But when my low beams went out my plow lights still worked .
  7. murdog94
    See you failed to mention that you have a plow. I cant really help you much there since ive never had a problem with lighting on a plow. But it does sound like you have a crossed wire etc..
    And alot of the plows that i have delt with and or driven have had it set up where the only lights that worked were the ones on the plow.
  8. quicksilver8817
    well an update the switch that switches my headlights to the plow lights was going bad..
