Bouncing Speedo
Discussion in 'Chevy C/K Truck Forum' started by jroc, Jun 20, 2012.
  1. jroc
    jroc New Member
    While driving today the speedo in my 92 k1500 w/5.7 started bouncing at first was bouncing between 60 and 80 then started bouncing between 0 and 80 not sure what the deal is with it can someone help before I go bald from frustration...
  2. tbplus10
    Try lubing the speedo cable.
    I would use graphite to lube it with, dry lube works best with these type cables.
    You'll probably have to remove the cable at the back of the cluster and shoot graphite into the cable housing.
    Sometimes you can get away with shooting graphite into the cable at the other end at the transmission connector and the graphite will work it's way up the cable, but this isnt a guarantee.
    If you do attempt to lube it from the transmission end check the speedo gear while you have it disconnected for any nicks or chewed teeth.
  3. jroc
    jroc New Member
    Looked at the tail shaft it has an electrical plug didn't find a cable. The speedo is acting like a tach
  4. tbplus10
    I thought 92 was still a cable drive, hmmmmmm.
    Might be the transducer then, unless you have a bad connection.
  5. jroc
    jroc New Member
    not sure I unplugged the connector at the tail shaft the needle dropped. When I plugged it back in the needle started bouncing again. Really dont want to take it in for this have a road trip coming up and need the truck in working order and safe...
  6. jroc
    jroc New Member
  7. Chris Miller
    It's probably just a bad speed sensor/dirty connector then.
  8. jroc
    jroc New Member
    cleaned the connection on both the sensor and the harness still bounces....
  9. jsmith4816
    jsmith4816 Rockstar 4 Years 100 Posts
  10. jroc
    jroc New Member
    Its close but the speedo does not react to the turn signal. The speedo starts bouncing as soon as the truck is started and put in gear. This morning truck didnt want to start fuel pump turns on but no fuel at the injectors recently installed new fuel filter.
