Brake Caliber bolts
Discussion in 'General Chevy & GM Tech Questions' started by Mike805, Feb 21, 2009.
  1. Mike805
    Mike805 New Member
    Its time to change brake pads on my 01 Chevy Silverado Z71.
    Heres the problem, the brake caliber bolts wont break free when trying to loosen. Ive already stripped one bolt.
    So whats the trick of getting out the stripped bolt and getting the others out to change brake pads.
    Never had this problem of changing brake pads before.
  2. dwill3015
    Welcome to the site! I would suggest penetrating oil, or heat to break it loose. We'll see what other members recommend as well.
  3. thatjerk01
    thatjerk01 Rockstar
    i would say use penetrating oil. spray it let it sit a min or two then spray it again. u gotta let the stuff work.
  4. spyder2000
    spyder2000 New Member
    When you write 'stripped' do you mean the bolt came out in one piece but the threads are damaged? Or did the bolt break off in the caliper hanger?
    I've never had either of these happen. The bolts are tight but should never be that tight. If they seem to be so, be sure you are turning them in the right direction since you are loosening them from the back of the bolt.
    For those that remain, try a penetrating oil like PB Blaster (there are others) shot between the disc and the caliper hanger to get to the hole. Give it 15 minutes to work, then try to release the bolt. If that doesn't give, then try heat from a propane torch.
    If the bolt broke off in the hanger, you will have to remove the disc (and bearings) to access the hole in the caliper hanger to drill and easy out the remainder. Penetrating oil and heat is used here as well.
    Not a bad idea to remove those bolts every year or so when you inspect brakes, clean them up with solvent to free the sleeves, then lubricate them well with high temp silicone grease and reinstall. This is also what allows the caliper to slide freely.
  5. cascott325
    lefty loosey, righty tighty! lol
  6. Z71_guy
    if you stripped the head of the bolt get a two vise grips, put one on the stripped bolt head and use the other to tighten the vise grip as tight as you can go then try to break it loose that way( use penetrating oil first)
    I use this method to get out stripped oil drain pugs
  7. FireRed
    FireRed Rockstar 100 Posts
    Always use heat to soften the "Loc Tite" !! Many get crazy over tightening them they should be torqued to 25lbs using lock tight. If in fact you have ruined the threads go to any decent auto supply and buy replacement bolts for stripped threads they will cut a new thread and save the day.
  8. Mike805
    Mike805 New Member
    Thanks everyone for the replys.
    After working four hours straight I finally got all four caliber bolts out. Everyone of them I had to heat, beat, spray. I never had such a time with brakes in all my life.
    I had to buy4 new caliber bolts. Cause the only way I could get these suckers out was putting vise grips on the bolt by the rubber seal and beating with hammer while heating with flame. Who ever worked on these brakes before must of used supper glue instead of lock tight.
    At lease the new caliber bolts have bolt heads instead of those dam star crap heads.
    The front brakes are all done and after I rest up and calm down I will tackle the rears.
  9. CarpenterGuy
    CarpenterGuy Epic Member 5+ Years 500 Posts
    oh man i hate those "torx" bolts or what ever they're called. my grandpa had those on his '90 gmc safari when i did the brakes on it. it was stupid. he blew up the engine like 4 months after that too. he said he had the oil changed that day so i didn't check it. i probobly shoulda looked any way. i hate it when people take advantage of old folks
  10. bzboardco
    bzboardco Rockstar 100 Posts
    One Suggestion----I just recently did that to my 02 silverado those torx bolts were hell and once removed I took a bolt to a hardware store and bought 4 hardened bolts (black ones) with 21 mm heads the next time it will be easier....Just my 2 cents
