Brake issues on 99 Suburban
Discussion in 'General Chevy & GM Tech Questions' started by Mack46, Nov 23, 2011.
  1. Mack46
    Mack46 New Member
    My suburban brake pedal has started sinking to the floor on most stops. When it sinks the brake light will come on but if I release pressure and press again it will be pretty stiff. What would cause this, I have bled the system and had the system flushed. I am not losing fluid so could it be the master cylinder? Any help would be appreciated.
  2. KidHauler
    Welcome to GMTC.
    Provide us with some more info of your truck;
    1/2 or 3/4 ton? (does it have hydro-boost)
    Have you scanned for codes? (anti-lock module)
    Have the pads/shoes been checked?
    This place is full of knowledgeable folks.
    Good luck,
  3. Mack46
    Mack46 New Member
    It's a 1/2 ton 2wd Suburban, nothing came up when we ran the codes and no I haven't checked the pads yet. I replaced the pads not too long ago though... This is my wires car so I rarely drive it but did have the opportunity last night. First push is very loose sometimes will catch and have good pressure but most of the time the pedal goes to the floor but the car does stop. If I release the pedal is going to the floor and release the pedal and push again it always has great pressure. Like I said before the break light only comes on when the pedal goes to the floor and then will go off by itself. Thanks again.
  4. 2COR517
    Sounds like the master cylinder is leaking internally
