Brake Light Problem
Discussion in 'GM Electrical Tech' started by Jarrett, Dec 30, 2009.
  1. Jarrett
    Jarrett Rockstar 100 Posts
    On my 1998 Chevy K-1500, my brake lights do not work all the time. They will work sometimes when I push on the brake pedal, but then not at other times. Could this be a bad switch? I'm not sure what the problem is. This just started happening today.
  2. Eddie Z71
    It could be the switch. I'm not sure if the wire is loose, or something else. I hope it is something easy, and someone can give you a answer soon. Good Luck!:glasses:
  3. jmutto
    jmutto Rockstar
    I would check for the following before replacing the switch:
    Bad ground.
    Corroded bulb sockets.
    Broken or frayed wire.
    I had the same problem with an old Dodge pickup; it turned out to be a bad ground.
    Good luck.
  4. Stealth
    is that a good bad ground or a bad bad ground? :lol:
  5. jmutto
    jmutto Rockstar
    BAD GROUND!!!! You go sit in the corner and think about what you did!!!
  6. Stealth
    do you want some cheese with that whine?
    DAMN,,,,you all have fun again without me .:lol:
    CRACKERS ON THE COUCH !!!!!!:rofl:
  8. Jarrett
    What about my brakelights?
  9. TritonBoulder47
    Your tail light board might need a good cleaning as well...
