Brake light system failure
Discussion in 'General Chevy & GM Tech Questions' started by Aititi, Apr 17, 2009.
  1. Aititi
    Aititi New Member
    Hi everyone,
    I have a 2004 Silverado, 5.3, ext cab, cruise control, non moving pedals (think this is all the info needed for this)
    I noticed a problem with my brake lights, both are out but the cab brake light comes on. I also noticed the signal lights work.
    Both of my brake lights went out so First I replaced both bulbs. That didn't work so I checked my fuses and they appear to work, I tested this by swapping out the fuzes then tested to make sure it wasn't the fuze.
    I then replaced the brake switch. This didn't work. To make sure that I was getting power then I used a test light at the fuse box and i was getting power.
    Then I replaced the signal light switch. Now this hasn't fixed it either and the person who was helping me is out of ideas
    Anyone have any recommendations as of what I could test now? I was looking for a wiring diagram for the signal light switch to see if power is making it from the brakes to it but I couldn't find it, and I'm unsure which wire to test.
    Any help would be greatly appreciated...
  2. ct9a
    If you have power at the bulb sockets, but the lights still don't light up, it may be a grounding issue.
