brakes issue ? need some help please ..
Discussion in 'General Chevy & GM Tech Questions' started by quicksilver8817, May 27, 2012.
  1. quicksilver8817
    quicksilver8817 Rockstar 100 Posts
    1990 k1500.. pedal hard at park and does not stop when put in drive .. pedal hard at low speed and does not want to stop but at cruising speed stops just about normal.
  2. 08_rado_rocker
    08_rado_rocker Member 2 Years 500 Posts
    Hmm.. could be a small vacuum leak it sounds like?
    Engine not creating enough vacuum to create the "boost" in the booster, but at higher engine speeds creating enough.
    I'm sure someone else will step in and give input as well.
  3. tbplus10
    Try putting the truck in park, revving up the engine, then trying the pedal.
    Does sound like you have a small vacuum leak.
  4. dpeter
    Don't rule out bad vacume booster diaphram.
  5. 08_rado_rocker
    :great: was gonna go there next if other didn't solve the problem.
  6. Josh
    Josh Member 100 Posts
    sounds like my old mustang. had a bad booster leak. only stopped when up in the rpm range.
  7. quicksilver8817
    well i just bought a master cylinder because its leaking anyway and the dont have the booster in stock .. anyway to che vacume on booster?
  8. dpeter
    Get a hand held vacume pump and draw a vacume on the booster and see if it holds. Might be able to trace it to the booster by removing vacume line and plugging it to see if engine idle changes with it on and off.
  9. quicksilver8817
    i pulled the vaccume line off .. engine is sucking .. i think its the booster because the problem persist with the vaccume line off leading me to believe the booster is not getting vacume ..
