break lights not working
Discussion in 'General Chevy & GM Tech Questions' started by jimjim1234, Jun 14, 2009.
  1. jimjim1234
    jimjim1234 New Member
    my break lights are not working but all my bulbs r good and also all my other lights are coming on. I relocated my groung. trurnig signals,backup light, and night time running light is coming on thoe. I tried everything would there be a fuse just for the break light. If any one out there can help me that would be good thanks:grrrrrr:
  2. 99'HEARTBEAT
    What year is your Ride??,that would really help in giving you some Advice.
  3. 2COR517
    And did you say the rear turn signals are working? Are they the same bulb as the brake lights, or separate?
  4. daddytech
    could be (depending on which vehicle you drive) that the circuit board that the tail lights are plugged into might be having an issue, could be a loose ground , or more often than not i have seen this issue with someone having incorrectly hooked up a trailer light kit in the truck also in which case you can simply unhook the trailer light wires and it should start working again.
    hope this helps some but without knowing what kind of truck you have or what year model it's kind of hard to be more specific.
  5. jimjim1234
    my bad i got a 78 chevy k-10
  6. jimjim1234
    And yes my turning signals are working too.
