Break pull
Discussion in 'General Chevy & GM Tech Questions' started by aaronbircher, Oct 29, 2009.
  1. aaronbircher
    aaronbircher New Member
    2000 K3500 DWR. When I break the truck pulls left. Otherwise it drives great.
  2. 2COR517
    The problem is likely on the right. Something could be preventing one of the right side brakes from working properly. Stuck caliper or bad flex line are the most likely culprits.
  3. Loggerhead Mike
    like 2cor said
    check your pads see if they are all wearing the same. most likely a stuck pad, caliper slide, or siezed piston, but it can also be an alignment issue. make sure all your tierods/ balljoints ect are tight
