Broken Heater Hose Assembly at Intake
Discussion in 'GM Powertrain' started by jgrimmster, Dec 4, 2010.
  1. jgrimmster
    jgrimmster New Member
    GMs are infamous for the heater hose connectors breaking off at the intakes, leaving the threaded portion in the intake. Does anyone have any suggestions on how to remove the threaded portion from the intake?
    I have attempted to use 2 pipe extractors, one was to large the other to small.
    2000 GMC Youkon Denali 5.7L
  2. grandparon
    grandparon Member
    Well, you need to get the right tool for the job. Get the right size and it should come out. Spray a little penetrating fluid on it also if it is stuck.
  3. tbplus10
    They usually snap off because their corroded, as stated get the right size and try that, if thats not possible I have had success removing them by using a dremel tool to cut a slit down the inside of the portion threaded in and chipping it out with picks or a screwdriver.
  4. neverenough
    neverenough New Member
    +1 had to do it years ago in my '97. buy the machined one to replace, not the cast junk!
  5. 2COR517
    The cast pot metal is the problem. As mentioned, dremel, chisel, pick, whatever you can use. I think you can get a repair kit at Napa too. The extractor might not be much help at this point, but the tap to clean the threads would be useful.
  6. jgrimmster
    Good News: Threads are out :party:
    Bad News: Manifold broke in the process :grrrrrr:
  7. ntbush83
    Oh no! That sucks! Broke it bad?!
  8. jgrimmster
    Added a pic above
  9. jgrimmster
    Tapped the outlet on the intake and used J B Weld to fix the part of the intake that broke. System is holding water and working fine.
  10. jgrimmster
