Brush Guards???
Discussion in 'General Chevy & GM Tech Questions' started by philosofy1, Oct 15, 2009.
  1. philosofy1
    philosofy1 Member
    I'm thinking of getting brush guards put on my 1998 Chevy C1500, But I also want to install a set of tow hooks in the front. I know this might sounds like a dumb question, but if I have the hooks will I still be able to get the guards?
    Where do the guards mount to on the frame?
  2. philosofy1
    philosofy1 Member
  3. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    on my jimmy the guard mounted where the tow hooks are so I had to lose the hooks, I'm not sure... but if you got longer bolts you should still be able to mount the hooks. hope it works out for ya
  4. Loggerhead Mike
    depends on the style of brush guard you put on. ive installed some that fill the frame holes where you hooks mount, and ive installed some that mount with your hooks and use the same bolt holes but the guard would be on the outside of the frame instead of inside
  5. fd8215
    fd8215 Member
    most of them I found mount where the tow hooks mount, so it may be one or the other sort of thing.
