building a motor on a budget
Discussion in 'GM Powertrain' started by txmj83, Jan 9, 2012.
  1. txmj83
    txmj83 New Member
    I got an old tired 350 in a 79 blazer. I'm on a tightbudget.
    I need to save up for a motor rebuild. I don't want a race car motor just agood strong motor.
    It's not a daily driver just a play toy. How much do i need to save??
    Can i get away with just replacing gaskets and seals and hone out the block andthrow in some new rings??
    I'm just tired of having to add oil every time i add gas.
    I know you can't give an exact I'm looking for a Ballpark amount.
    thanks for yalls help.
  2. aloxdaddy99
    I would guess it shouldn't take more than a grand. The other thing I would add to the list is is to have the block checked for cracks. For that gen motor parts are fairly cheap.
  3. Boonduff
    It's hard to give a number on something like that. You never know how worn the motor is until you tear it down. Cylinders may or may not need boring out, head deck may need to be resurfaced, mains may need to be alignbored, and you'll diffently want to have the heads redone. You'll only know the answer once its torn down and is inspected.
  4. vncj96
    Just get a worst case estimate from a machine shop that you would be comfortable doing the work on. Another possible outlet would be a college in your area that has an good automotive engineering program (or something close), they may be able to do it for you for dirt cheap if not free. the college I went to had it and they even had 2 dyno to use so they were always looking for people to run some high HP cars through or even some that had an audi or subaru for the AWD dyno.
