can anyone help me???
Discussion in 'General Chevy & GM Tech Questions' started by Paul Whyte, Jan 8, 2012.
  1. Paul Whyte
    Paul Whyte New Member
    ok so I have a 1994 chevy k2500 with a 454 in it. I am having trouble driving it. it starts up fine like nothing is wrong with it but when u try to accelerator it tries to stall. I have replaced the fuel pump about 4 months ago, the filter also, I have replaced the timing chain, distributor cap, an rotor, new plugs an wires, ignition module, ignition coil, throttle posotion sensor, set timing, took off the catylatic converter, Idk whats wrong need help....
  2. tbplus10
    Have you checked the injector pressures?
    Also might want to look at timing advancement, this yr model is electronic computer controlled so you'll need to look up the troubleshooting tecniques for it.
    "took off the catalytic convertor" that'll give you some codes right there that may confuse the issue when troubleshooting, you'll have to sort that out first. Have you checked for any codes yet?
  3. Paul Whyte
    yes i have but no codes pop up. its starting to make a loud sucking sound coming from the throttle body it happens off an on.
