Can OBD II scanner read OBD I ????
Discussion in 'General Chevy & GM Tech Questions' started by ejohnson03, Dec 16, 2011.
  1. ejohnson03
    ejohnson03 Epic Member 5+ Years 1000 Posts
    Dumb question...
    I have a 94 Silverado, does this have OBD I for scanning codes?
    Found a OBD II scanner at Harbor Freight for $50.
    Can it read OBD I codes?
  2. sstoner911
    You can get an adapter so that the OBDII will fit the port on a OBD1 vehicle. They run around $20 bucks last time I saw one.
  3. ejohnson03
    good deal, I'll be checking ebay for one.
    Figured for $50 I could use it for both OBD-I and OBD-II scanning.
  4. dipstick
  5. MrShorty
    You'd probably be better served asking the manufacturer or looking at the tool's documentation to see if it can read the older computers. My gut feel is that, for only $50, it probably can't
    Also, as noted, a special scanner is not needed to read OBD-1 codes on these. A simple jumper wire and the ability to count is enough to get trouble codes.
  6. dipstick
    Only thing it will do on obd1 is jumper points a&b..will still have to watch light for codes.
  7. Ethan
    Ethan Rockstar 100 Posts
    No, if you want to read codes off of an OBD I system you need to get the GM Tech 2 with the OBD I adapter, then you can read codes, run tests, clear codes, program the PCM to some degree, and monitor all live input data. I've done it many times with my 94 chevy using a Tech 2, you can usually find them cheap on Ebay since they are outdated.
  8. dipstick
    Not only thing it will do ..retrieve codes quicker ...had some jump ahead vehicles in 94..95 could read some live data.. was 16 pin scan port
    But was still obd1 complaint.
