Can you do it?
Discussion in 'Lifted & Offroad Suspension' started by drakeoz71, Mar 4, 2010.
  1. drakeoz71
    drakeoz71 Member
    I was wonderin if you can get a 3" leveling kit and a 3" body lift so you would pretty much just have a 6" lift?
  2. chschevy58
    chschevy58 Rockstar 100 Posts
    yes yes yes. i have a leveling kit and plan to add a 1.5" BL to make my truck sit higher
    1 person likes this.
  3. drakeoz71
    drakeoz71 Member
    goood. Cause i cant afford a 6" lift. Do you think i should go with bigger shocks?
  4. Eddie Z71
    I think your truck will look great after you do this! Keep us informed on how its going.:glasses:
  5. adampaul1964
    If you just do a leveling kit (3") you won't need shocks, the body lift doesn't involve the suspension at all.
  6. hbfsbull
    hbfsbull Member
    I have a 3" body lift with a 3" leveling kit on my truck running 35" tires . you will need new shocks for the leveling kit as it raises the front suspension .
  7. Pete95Sierra
    yea you can do it, but the rear is still gonna only be at 3". You could always add a 1" or 2" block in the back tho under your leaf springs. And yes, I would highly recommend new shocks in the front
  8. abraham.issac.jacob
    abraham.issac.jacob New Member
    If you plan on using your truck for hauling and towing a lot of miles I would stick with a leveling kit and 33" tires, anything bigger is going to make it worse for towing and hauling and probably cause problems as the miles rack up, plus you will have issues getting warranty work if you need it on the drivetrain.
    wheel castors
  9. adampaul1964
    I say again, with a 3" leveling kit on a 1500, you don't need shocks.
  10. hbfsbull
    hbfsbull Member
    You dont "need" new shocks but i would recomend them as you WILL be raising the front suspension three inches therfore decreasing your upper shock travel by three inches . Its better to have longer shocks than to take the chance of limiting out the upper shock travel on stock shocks
