Cargo/LED Bed Lights
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Dexter04, Jan 11, 2017.
  1. Dexter04
    Dexter04 New Member
    So here's something that annoys me... having to walk all the way back to the cab to switch on my cargo lighting when I'm loading or unloading something at night. Other manufacturers put a switch right at the back for you to use. Why they don't put a sensor on the tailgate is beyond me.
    Has anyone ever wired in a bed switch that works with the factory system?
  2. thegawd
    thegawd Rockstar 2 Years 1000 Posts
    hmmmm if you could find a wiring schematic and figure out if its switched by the ground side it wouldn't be hard to re wire at all. but it might not be switched that way and you would have to run a new set of wires and wire it the same way a house switch for a stairwell operates so both switchs can operate the same lights. ya I think it would be convenient if there was a switch right there as well.
  3. RayVoy
    Just leave your door open a little.
    Al, the Body Controller switches that light, not as easy as it use to be.
    thegawd likes this.
  4. Dexter04
    Dexter04 New Member
    Lousy new vehicles... the BCM does everything. I miss the days when I could add a relay or a switch here and there to change things that bother me. I have a background in computer programming and electronics... one day I will get my hands on a spare BCM and figure out how to "tune" it. ;)
    thegawd likes this.
  5. RayVoy
    Ok, so you add a switch.
    The knobs we turn are just user interfaces; you turn a knob, the BCM receives an input signal.
    Just parallel the dome/cargo light switch. As long as the BCM receive a "light on" signal, it will turn on the light(s).
    thegawd likes this.
  6. thegawd
    ahhhh great idea Ray! that should work!
  7. RoarinRow
    RoarinRow New Member
    I'm looking at these LED bed lights from Amazon. Haven't pulled the trigger yet but I want to. Just need to watch more YouTube videos on how to install.
  8. tbplus10
    On my 2011 I added led bedlights on my tonneau cover bows and wired them from the battery to a water proof switch mounted under the bedrail next to the tailgate.
    The only thing I'd change is at the time the vendor I bought from only had red lights, should've waited until white lights were available.
    RayVoy and thegawd like this.
  9. Dexter04
    Dexter04 New Member
    Having the lights back there is great... especially with a tonneau cover.
  10. RoarinRow
    Yup which is exactly why I'd be nice to have. Otherwise, I'll just use a flashlight when I need to.
