CB installation
Discussion in 'Audio, Video & Gadget Tech' started by devilsalmostfree, Feb 18, 2010.
  1. devilsalmostfree
    devilsalmostfree Rockstar 100 Posts
    i did a search & found nothing. just wondering where u all r mounting ur cb's & anteenas! pix r welcomed! thanks in advance!
  2. rwslippey
    rwslippey New Member
    While I'm really not a "cb'er" (licensed Ham operator) I thought I could add a few ideas for you....
    I've seen people "mount" CB radios in betwen the seats... (buck seats obviously) if you can call it mount... The only suggestion I can come up with for location is whatever floats your boat.. I like my amateur radios down low so the light from the display doesn't become a distraction. Some options may be (depending on your vehicle ) a void space under the dash (I'm driving a 99 suburban and ttheirs space between where the dash dropps to the hump and the consol, again whatever suits you...
    As far as powering and antennas go I would suggest a direct fused connection to the battery (easy to accoplish by just passing some a positive and negative batter wire thro the grommet at the firwall (be carful to put it thro the grommet not between the grommet and the metal and not to mess up any stock wiring harnesses... (also be sure to secure your the wires and keep them away from sharp edges of metal.... this will eventually wear the wire away and short out (this is the reason for the fuses being at the battery)... depending on you vehicle and the noise you may get in the reciever you may want to also add a noise filter.
    Antenna locations varry.... i currently have a NMO mounted ant (again for ham not cb) on the roof rack of my truck.... It's worked for several years and has recently had some trouble... (their is a small hole drilled thro the rack into the vehicle to pass the coax(wire for the antenna) somewhere along the line it met some medal that I missed and I now have to completly replace the coax.... Perminent installs are much better than semi mermenant mag mounts... the best place for an antenna on a vehicle is in the center of the vehicle as much as possible (gives a good ground plane for the antenna to radiate off of)
    Their are various types of mounts you can use depending on your vehicle (not sure if they make an NMO for CB's ) if you plan on a permentantly mounging this and are willing to drill holes google antenna install for cb and ham radio on trucks and see what you can find.... mirror mounts aren't a bad way to go but... again it's all preference ....
    good luck with your install
  3. redneckarmyMP
    redneckarmyMP Epic Member 5+ Years 500 Posts
    i recently replaced my jumpseat with a center console and ive been thinking about mounting mine somewhere in or on the console
  4. Stealth
  5. devilsalmostfree
    thanks for the info, im really wanting to steer clear of drilling holes in my truck. i figure ill get a friend to make me up some kind of bracket. i just gotta figure out where i want it at (gotta keep it outta the way for hauling my hay) & go from there!
  6. Beer Belly
    Beer Belly Rockstar
    If you look at the picture in the link provided by stealth, under the dash right above the gas pedal is where I mounted my CB....I drilled into the metal bracing to mount it. Right now I have a magnet mount antenna on the roof, but looking for options.....I saw somewhere where there was a bracket that mounts under your hood that you can bolt an antennae to that comes out from the cowl area to match your radio antenna on the other side.....I think it was on the GM-Trucks.com website.
  7. devilsalmostfree
    cool thanks man!
  8. rwslippey
    Like I said (in way too many words...) it's all a matter of person preferance... I like my equipment mounted clean and together. Looks good ... easy to keep wires out of the way and doesn't go flying when someone cuts you off and you hit the breaks to the floor...Modt truck stops carry mirror antenna mounts and you can buy a decent antenna their while your at it( may be a little over priced) you can also look around online for mounts ... I know someone makes a mount that goes under the lip of the bed of the truck and is pretty secure.... I used one on my dodge for a while and it worked well.... no damage to the pain and no holes... good luck
  9. rwslippey
    If I understand your post corrently (your asking what to do about the wine) .... The noise your getting could be (most likely) from 1 of 2 places or both .... the alternator... or the fuel pump....
    If it's the alternator you may want to try a direct connection to the battery..... (again fused at the battery and then you could find a noise filter which again goes at the battery..... If It's the fuel pump you may have to get involved a bit more.... before suggesting anything about the fuel pump I'd like to ask where your antenna is on the vehicle , how your power is set up (direct to battery or dc socket inside(cigerette lighter) and if you've tried disconnecting the antenna cable (coax) from the radio and idleing the engine.. see if the noise is still present?
  10. betts687
    betts687 Member
    has anyone tried running the cb wire (or any wire) through the cargo light to the roof? i saw a truck like that yesterday, but wasn't sure about water leaking.
