change oil light
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by lindsaynuts8, Oct 5, 2012.
  1. lindsaynuts8
    lindsaynuts8 Member
    i have a message center in my truck that reads change engine oil which i did but cant figure out how to get this notification off. i do not have my manuel so i was wondering if u guys could tell me how to do this? thanks :)
  2. moogvo
    Turn the key to the run position but do not start the engine. Slowly press the accelerator pedal to the floor and release 3 times. Your message center will indicate the oil life monitor has been reset.
  3. Pikey
    x2 on what [MENTION=12002]moogvo[/MENTION] said. But, I think that it has to pressed 3 times within 5 seconds.
  4. ChromeSilver02
    ChromeSilver02 Epic Member 5+ Years 500 Posts
    You're right, it is 3 times within 5 seconds.
  5. moogvo
    Yes, that is the case. I didn't think about that... I am just used to doing it now. LOL!
  6. lindsaynuts8
    lindsaynuts8 Member
    ok ill try it. so does it take time for it to turn off or it just does automatically?
  7. barefoot greg
    barefoot greg Rockstar 100 Posts
    if you have buttons on the steering wheel i believe it can be reset this way aswell, as my change oil light is on aswell im gonna run out n see if i can get it to go out.
  8. j cat
    ignition on throttle pedal to the floor 3X in 5 sec. then the light will flash and its reset.
    10 sec. total time.
  9. lindsaynuts8
    lindsaynuts8 Member
    thankks guys :) it worked
  10. Jimmeh
    Not sure if it does it to anybody elses truck, but mine will tell me that the oil life has been reset upon start up for several start ups, post reset. It has done it since about the 5th oil change I've done. Not a big deal because it does eventually go away.
    Also, don't rely on that "Change Engine Oil" to change the oil. 3-5,000 miles is recommended. I let my truck go all the way to the next time that prompt came up once, and it was about 8,000 miles after I changed it the last time.
