Changing Diff Fluid....
Discussion in 'Maintenance & Upkeep' started by sstoner911, Jun 13, 2011.
  1. sstoner911
    I am going to be changing the diff fluid on my Wifes 2006 Dodge Ram 1500....it takes 75w-140 synthetic....the truck has limited slip and the bottles of oil state "limited slip"...so do I still need to add the limited slip additive?
    Also is there a gasket or anything I need to replace while i am there usually?
  2. ntbush83
    I don't think you need the additive if it already says limited slip fluid. Also yes make sure you get the gasket!!!
    Also get a few cans of break parts cleaner cuz while you have that rear pan of go ahead and spray that stuff in there and it will clean out all the grime and old oil.
  3. Rockstarrchevy81
    Rockstarrchevy81 Rockstar 3 Years ROTM Winner 1000 Posts
    how often does anyone need to change diff fluid? I plan on changing mine sometime before next month.
  4. TELORVEHC
    My Haynes manual says every 60,000 miles or 48 months, thats for the 1999-2006 models. It's probably the similar if not the same for the NNBS trucks.
  5. Rockstarrchevy81
    oh okay ha well that puts me at perfect timing then thanks man.
  6. aloxdaddy99
    Stoner what brand of gear oil are you going to use? Just interested in what other people use and if they have any particular reason for using that brand. I have heard a lot of good things about Amsoil products. I started using it in my Harley and do notice a little difference in hoe the motor runs.
  7. racekid91
    racekid91 Rockstar 3 Years 100 Posts
    Just did mine two weeks ago. I pulled the cover, cleaned everything up with brake cleaner. New gasket. Used a friction additive for my G80. Also did my front differential. Just a drain and fill.
  8. sstoner911
    I got valvoline synthetic....i looked at lucas and some others but they didn't have the weight I needed.
  9. Rockstarrchevy81
    I plan on changing my diff fluid and gasket. Which kind of diff fluid and weight along with which kind of gasket. Also can i pick this up at autozone etc. ?
  10. TELORVEHC
    You can probably find what you need at Autozone, Pep Boys etc.... I'm sure they'll have it.
