changing tail lights
Discussion in 'GM Electrical Tech' started by Blamson87, May 8, 2013.
  1. Blamson87
    Blamson87 New Member
    Hey need a little help guys I have a 2003 GMC sierra 1500 and I was wondering if 2003 to 2006 tail lamps would be able to switch with the ones I have on my sierra I'm talking about to ones that have to two bubbles and I have the normal just red with yellow blinker anyone please help me and of so do I need to do any modifying? Thank yo u
  2. ChromeSilver02
    ChromeSilver02 Epic Member 5+ Years 500 Posts
    They will fit in the same bed hole so no problems there, but you will have to change out the sierra wiring harness for a silverado wiring harness and no problem just plug and play. If you decided to not spend the money on wiring harness, you can shave the taillight or bulb socket to make them fit and then tape over the bottom hole where the extra little light bulb would be. I suggest buying the silverado wiring harness though.
  3. Blamson87
    Thank you for the advice really helps me out!! So the wiring harness isn't hard to do? Do I gotta run the wires very far?
