Charging issue
Discussion in 'Audio, Video & Gadget Tech' started by k.daddy1, Nov 14, 2008.
  1. k.daddy1
    k.daddy1 Rockstar 100 Posts
    I have an 03 chevy silverado. 4 months ago, I replaced the battery, this past weekend the alternator crapped out. I replaced the alternator and now the charging light in the dash stays on. I've checked the battery with a multimeter and I'm getting 14.6 volts to the battery while running and the same at the alternator. Why would the charging light stay on? Anyone have a clue?
  2. tlperry68
    Is there a solenoid between the altenator and the battery? That might be the problem. Other than that I really don't know.
  3. retired
    retired Rockstar 100 Posts
    Does the light go out when you raise the idle? Most likey the gauge is bad.
  4. raisor87
    raisor87 Rockstar 100 Posts
    disconnect the battery for 10 minutes, or just drive it your pcm can take a while to reprogram itsself or bad voltage regulator ?
  5. k.daddy1
    Light doesn't change with idle, I've took the alternator back to NAPA and had it tested. They said it was good. I'll try the battery disconnect and see what happens. Thanks
  6. Thundare
    Thundare Rockstar 100 Posts
    try Replacing the battery, in my 96 Tahoe i was going bazerk, so i replaces all the electrical and it still was goin crazy, batter seemed fined, untill i was going up a hill and the engine starts to cut out, THE BATTERY WAS FRIED, it turned out that the battery malfunctioned, but still showed Volts and amp, i replaced it. totally fixed the problem. i put out a bunch of money just for a damn 70$ batter. that suked ,
