Chevrolet Colorado Wheels?
Discussion in 'Chevy Colorado Forum (GMC Canyon)' started by retired2001, Nov 27, 2008.
  1. retired2001
    Does the Chevy Colorado use the same wheel lug pattern as the full size Chevy?
  2. Gregsyellorado
    Gregsyellorado Rockstar
    Yes it has the same 6 lug pattern as the fullsize Chevys/GMC. Also the Nissan Titan wheels will work, as well as Toyota 6 lug, and also Mazda 6 lugs. All ot these wheels you will have to bore the center hub to 104 mm to get them to clear. Hummer H3 wheels are a direct bolt on, with no modfications. The wheels from the Trailblazers/Envoys,and the SSR's will not work they are a different lug pattern. I have also heard the Ford 6 lug wheels will work but they require redrilling the lug pattern, plus the center bore. Hope this helps.
  3. retired2001
    Tlhanks for the info'! I am looking at making a Colorado my next truck and have extra full size 17" wheels.
  4. New Member
    Would those wheels fit an 02 Trailblazer?
  5. fltinstructor
    fltinstructor New Member
    No, The Trailblazer has a different wheel bolt pattern.
  6. markmc
    markmc Member
    The Trailblazer is hubcentric also..
    I went with adapters/spacers to the 1/2 ton lug centric pattern..
    Those Evil GM designers
    NORMSCOLORADO Rockstar 100 Posts
    As far as i know they will fit just the CC rim has a larger center bore for the hub....
