Chevy Cluster
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Superchevy01, Apr 25, 2010.
  1. Superchevy01
    Superchevy01 New Member
    Chevy Cluster problems
    The cluster in my 01 silverado is not workin right. The batt. light stays on and my gas and temp gauge doesn't work. My abs light doesn't come on and my tow/haul isn't working. My odomater and PRNDL goes off in the run position. I allready tryed replacing the cluster and ignition switch. Does anyone know what the problem could be? ????I am stump on this!
  2. murdog94
    Blown Fuse??? Or else might actually be your computer since that is what sends the signals for the cluster...
  3. Superchevy01
    I did check all the fuses as well. Do u mean the PCM or BCM?
  4. murdog94
    Pcm..............
  5. Superchevy01
    Is there a way to test it? because i know that pcm aren't cheap
  6. murdog94
    Not to sure about that. I hope someone else can point you in a good direction for that.. sorry
  7. Superchevy01
    okay thanks for the help
