Chevy Silverado 2010 Differential Sound
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Majed, Oct 31, 2013.
  1. Majed
    Majed New Member
    Hi,
    I own Chevy Silverado 2010 LT, Auto transmission.
    For last few days im hearing a humming sound from the front differential when the car is in auto.
    When i put it on 2WD there is no sound.
    What can be the problem. i checked the fluid level its ok.
    Any Suggestions?
  2. j cat
    as the vehicle ages you will get some sound from the front diff when in auto or 4wd. also a slight vib .
    do not use this vehicle in any 4wd selection on dry solid pavement. this will cause damage to the drive train. only use 2wd high .
    also be sure to rotate the tires often 10-13K miles to ensure they are all at the same wear .
  3. Majed
    Majed New Member
    Thanks J. Cat for the suggestion, I have new tires and I'm not a off road guy. The car is on 78,000km.
    Any other thing which I can change and fix the problem?
  4. Pikey
    You can change the fluid in your front diff. You have about 50000 miles on it, so now would be a good time. I have an 05 with a new front diff and new transfer case. I get the same noise you describe in auto and in 4wd. I only use 4wd, I never use auto. I only use 4wd when there are 6+ inches of fresh snow.
  5. j cat
    the drive train fluids should be checked at every oil change for level and color.
    when my silverado was new I had to replace the front diff fluid every 5,ooo miles 3X then the oil stayed clean. I was getting a discoloration of the oil. after that I replace at the 40,000 mi mark with just normal light duty trucking..
  6. stchman
    The vehicle the OP has is still under the 5 year 100K mile powertrain warranty. Take it to the dealer and let them look at it.
  7. Majed
    Majed New Member
    I changed the fluid but still the same...
    I will take it to the dealer but it will cost me fortune just to have checked up. :(
  8. Pikey
    If you are under 100,000 miles it will be covered under power train warranty as [MENTION=39185]j cat[/MENTION] mentioned.
  9. Majed
    Majed New Member
    sure i will give a try from the dealer. :)
  10. j cat
    my guess is this is normal. have the dealership go with you for a short ride and most likely this will be just a normal sound with this in 4wd....
    If your from canada you may have to pay .. with your mileage what drive train fluids have you replaced ? did you have the rear diff cover removed cleaned and the oil replaced .
    normal hum from the rear diff is also the norm.... replacing the rear diff fluid and cleaning out the box/magnet causes the rear diff to work faster and more efficiently.
    good luck ...
