Chevy Silverado Remote Programming 2007, 2008, 2009, 2010
Discussion in 'Chevy Keyless Entry Remotes' started by ChevyFan, Oct 24, 2009.
  1. ChevyFan
    Silverado Remote Programming Instructions for 2007 (new body style) - 2010
    Use this Procedure for Vehicles with Driver Information Center Buttons
    This information is in your Owners Manual in the Drivers Information Center Section.
    1. Insert your Key and turn to ON position so that the Driver Information Center display appears.
    2. Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays in the DIC.
    3. Press the set/reset button until REMOTE KEY LEARNING ACTIVE displays in the DIC.
    4. Press and hold the lock and unlock buttons on the first keyless remote at the same time for approximatley 15 seconds. A chime will sound indicating that the remote is programmed.
    5. To program additional remotes at this time repeat step 3.
      This vehicle can have a maximum of eight remotes programmed.
    6. To exit programming mode turn key off and remove key.
    7. Test remote(s).
    Use this Procedure for Vehicles without Drivers Information Center Buttons
    1. To access this display, the vehicle must be in Park (P) with key in the on position (as far as you can go without cranking engine)
    2. Press the trip odometer reset stem until RELEARN REMOTE KEY displays.
    3. Press and hold the trip odometer reset stem for three seconds. The message REMOTE KEY LEARNING ACTIVE will display
    4. Press and hold the lock and unlock buttons on the first keyless remote at the same time for approximately 15 seconds. A chime will sound indicating that the remote is programmed.
    7. Test remote(s).
    Chevy Parts
    Chevy Remote
  2. TMRuiz
    TMRuiz Rockstar 100 Posts
    Will this reprogramming of the remotes work if your original remotes didn't have remote start but the new remotes do have it. Will this make the remote start feature work?
  3. Vincennes02261897
    Vincennes02261897 Rockstar 4 Years 1000 Posts
    BUMP. Anyone know about TMRuiz's question? I'm also curious.
  4. shadetree
    shadetree New Member
    I have a 2011 Chevy Silverado with the Driver Information Center. I have punched every button and cannot find the display "RELEARN REMOTE KEY". If I could find this the rest should be easy to program a 3rd remote to keep as an extra. Does anyone know what I am doing wrong to not find this. Thanks
