Cleaning Black Diamond Plate Toolbox
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by JohnRoss1986, Feb 12, 2013.
  1. JohnRoss1986
    JohnRoss1986 New Member
    Any suggestions on how I can clean my tool box? You can't really see the build up past the pollen in the picture. But it's got a white film across the top. photo9.jpg
  2. Pikey
    I would pour some simple green on it and then go at it with a stiff brush
  3. SurrealOne
    Sounds like someone applied wax to it and let it dry?
    Apply Simple Green when not in direct sunlight (so it wont' dry out quickly), wait 3-5 mins, and like Pikey said -- use a brush. If that doesn't do it then try 3M Adhesive, Tar and Wax Remover.
  4. JohnRoss1986
    Ha! Caught...
    Aside from the white film the finish was starting to look dull too. That's why I tried waxing it.. I failed. Got some mean green last night, gonna give it a try. Thanks for the advice fellas.
  5. j cat
    if the box is not too old I would return it . the powder coat must be defective. the alum box requires a coating to prevent the alum from corroding . using acid cleaners/ strong cleaning agents will attack the finish.
    the alum will then turn white powdery as it corrodes.
  6. craigandi
    craigandi New Member
    soap, water, dry, then a sponge with wd-40 followed with a dry towel. works great.
  7. JohnRoss1986
    Thanks for all the input guys. I tested out a spot with mean green and it worked. It took away the white film and shined it up a little.
