Cleaning the corrosion from these "chrome" wheel skins??
Discussion in 'Detailing & Truck Care' started by steved, Jun 25, 2013.
  1. steved
    steved Former Member
    Washed the truck last night and found the chrome skins on the OE 17-inch wheels are corroded, center cap is fine...what is the choice of cleaner for them? They are chrome plated plastic correct? My normal approach would have been steel wool, but I wanted to make sure I don't damage them using that technique before I did that.
  2. KyleZ71
    I would usually say polish but they are only chrome painted plastic. Can you post a pic? Most of us would appreciate that.
  3. tbplus10
    Your trucks a 2012, before doing anything to them you might try visiting the dealer, see if theres a TSB.
    Dealerships can still sometimes surprise you and handle items like this, but only if you let them know the problem exists.
  4. ChromeSilver02
    ChromeSilver02 Rockstar 4 Years 500 Posts
    Try aluminum foil, it is softer than the chrome so will not scratch it and it does a chemical reaction with the corrosion. I am currently doing this on a set of chrome rims and works great. Now I do wonder if it will work on chrome plated plastic, I don't know if that matters. But at least try it.
    Also here is a link for the details that I found and helped me.
    http://www.robertscycle.com/chrome-clean.html
  5. BRB46
    BRB46 Rockstar 100 Posts
    Not sure if GM changed them,but my 2006 chrome covers were metal. I removed them to have painted wheels and was surprised to see that they weren't made of plastic. Had quite a time getting them off and destroyed them doing so. All bent and mangled. They may clean up better than you think with traditional chrome polish.
  6. marksoldtowne
    marksoldtowne Member 1 Year
    hi everyone
    now a days chrome wheel is very popular. chrome is relatively soft, it responds very well to polishing
    Frequent cleaning is the only way to keep your wheels safe.The soft, synthetic bristles loosen grime and brake dust without scratching the chrome.use non acidic cleanser to protect wheel finish.
