Clearing trouble codes
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dgill, May 9, 2009.
  1. dgill
    dgill New Member
    Hi Folks,
    Is there a way to clear trouble codes without a scanner. I know I should already have one but things are a little tight right now and I don't want to settle for a cheapy one. Thanks.
  2. Dr_Zero
    Try disconecting the battery for a few minutes and that should do it.
    Autozone and Advance can do it for free for you also
  3. Jimmiee
    One thing to remember about clearing codes is when you disconnect the battery you loose all your computer adapts along with all the presets in your radio and any other accessories that have memory. Not only that, you loose the snapshot of the code. The freeze frame snapshot has all the information on what happened when the code set. And last but not least, clearing codes can cause further damage to your vehicle!
