Climate Control Illumination
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by F E Knucklebuster, Aug 14, 2009.
  1. Are the red/blue bars on the climate control suppose to illuminate when the other dash lights are on?
    Mine never have and I recently saw a pic of one that was - not sure if this was a conversion or not.
  2. DIGS16
    DIGS16 Rockstar 100 Posts
    yes they are suppose to be on... mine some times dont turn on but i move the little handle up and down really quick and they turn on
  3. Tried your trick - worked like a charm. Thanks
  4. ClevelandWheeler™
    ClevelandWheeler™ New Member
    question, can I replace the manual climate control like yours with the digital one?
  5. kwconch021
    kwconch021 Rockstar
    yes sir, its a completely different cluster, you'd have to remove your dash and the 7mm screws holding it in, check all the pin connectors before you finish up tho, bc i had a digital in my other truck and the lights on that started to go out, the only thing i could think of as to why is the connections. im not too sure where to get the digital cluster but a quick google search and you should find what you need... maybe even
  6. ClevelandWheeler™
    Thanks for the info.
