Code 307
Discussion in 'GM Powertrain' started by Tony Arms, Oct 1, 2010.
  1. Tony Arms
    Tony Arms Member
    I have a 99 Silverado with a 4.8, code reader tells me cylinder 7 misfire.
    New plugs same problem. Can I swap the coil from another cylinder to see if the problem follows the coil?
  2. Chris Miller
    That's usually the first thing I do. :)
  3. murdog94
    Ditto on my end... Also the misfire could be a fuel injector as well.
  4. Tony Arms
    Tony Arms Member
    I'll give it a try and let you know what's up.
  5. Chevyboy420
    Chevyboy420 New Member
    yes common problem with rust in the fuel system!
  6. Tony Arms
    Tony Arms Member
    The coil and wires made no difference so I pulled the injector tonight full of dirt and rust. I'll see if I can find a replacement tomorrow.
  7. Tony Arms
    Tony Arms Member
    Ordered a new injector I'll be able to put it in tomorrow. Does anyone know if you need to refil the fuel rails with fuel before you start the truck ?
