Cold Engine
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by bill18163, Feb 10, 2013.
  1. bill18163
    bill18163 New Member
    I have a 2013 Suburban with the small V8 engine. Normal engine temp puts the gage right about on the 210 mark if I can get it there. In cold weather I cant even get to the 210 mark unless I get on the interstate and run it up to 65 mph. Then it will warm up. The other day I went up a hill to pick up a bag of ear corn and it did warm up to 210 going up the hill but coming back the gage dropped back to the half way mark and never got back to 210. The dealer put a new thermostat in it about a week ago but it still keeps doing this. In real cold weather it never gets past the half way mark no matter how far you drive. What else could cause this problem since the thermostat has already been replaced?
  2. Conlan Rose
    Those are perfectly normal temps. The thermostat is set at 195 usually My truck never reaches 210 unless it is a very hot summer day. Your Burb has electric fans that cool better than my mechanical fan so of course your temps will stay lower.
  3. tbplus10
    The electric fans could possibly be coming on and cooling things down, you can check to see if their running before the engine temp reaches I believe 180 range.
    Depending on how cold the weather is where your at it may just be that your engine is cooled to well and you could need to mask all or part of the radiator to get the temps up a little. Kind of like Semi's do in the winter time to keep their diesels running at optimal temperatures.
