complete transmission fluid change
Discussion in 'GM Powertrain' started by mvoss2576, Feb 26, 2010.
  1. mvoss2576
    mvoss2576 Rockstar
    I was told at the dealership that they recommended me having them do a complete transmission fluid change.. they charge $200 for this service... I understand draining the 6 qts or so by dropping the pan leaves some old fluid in there... how do they accomplish the complete fluid change.. is this something I can do?
    Thanks!
  2. Z71_guy
    at our shop we use a tranny flush machine, we take off the cooler line at the tranny and connect the flush machine and start the truck the pump does all the work complete is a little misleading you get most but never all of the old fluid.
    when you flush it is mixing the new fluid with the old so you wont get all of it out but i would say about 90% depending on the capacity of the flush machine i believe ours holds 17qts
    and that sounds a little expensive try going to a local auto repair shop we charge around $120 for a flush
  3. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Hes right, they need a tranny flusher to do it completely but its worth it. My local transmission shop did it for $95.
  4. 1st Synthetics
    You can do it yourself. I did it to mine. Here are the instructions. Let me know if you want a price on the fluid and filter. AMSOIL ATF is good for 100K miles.
    AMSOIL Automatic Transmission Fluid and Filter Change Procedures
    It is pretty easy to do, you will need someone to pour the fluid in wile you start the truck.
    I put a rubber hose on the return line and put it into a bucket to drain while I started my truck.
  5. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    I heard that a flush is bad for it? Its this true? I just dropped the pan and changed the filter & fluid for less than 50 bucks.
  6. Silverado Junkie
    No its not bad. Its basic matinance just like changing your oil. It should be done at certain intervals to keep your vehicle running great.
  7. Z71_guy
    only time when it can be bad if for high mileage cars that it has never been done before, flushing can actually brake up some of the junk in the tranny and may cause some problems( i have seen it happen on multiple occasions)
  8. Big75
    Big75 Rockstar 4 Years 500 Posts
    I have 180,000 on my 96. I haven't noticed anything slipping, if I was to do a flush you're saying it could create problems???
  9. Z71_guy
    not saying it will but there is a higher chance of problems, the majority of problems come from fords, GM seem to be a little safer on high mileage cars being that you change the filter and fluid you should be fine mainly applies to people who have not done anything
