condensate drain problem 2005 uplander
Discussion in 'Member Introductions' started by wsevans3, Jun 22, 2009.
Newest Photos
  1. wsevans3
    wsevans3 New Member
    Hi:
    I've got a 2005 chevy uplander that leaks water into the floor boards when the ac is running. We just completed a trip to FL from MD and the entire front of the car was soaked. I think its a condensation drain problem as when we stop no condensation flows out onto the ground. I've read a number of similar complaints but no one with a solution other than the condensate drain is blocked. Does anyone have a suggestion about how to solve this problem? Can anyone tell me where the drain is on the uplander?
    Many many thanks!
    Bill
  2. 5speedsilverado
    5speedsilverado New Member 1000 Posts 100 Posts
    welcome to the site!
  3. Z71_guy
    Z71_guy New Member 1000 Posts 100 Posts
    welcome to the site, not sure where it is located but look for a rubber tube hanging out under the it should be on the passenger side tucked up a little bit gently blow some air up the tube with a air gun and see what happens or take a flexible but stiff rope or something similar and run it up the tube
  4. ct9a
    ct9a New Member 1000 Posts 100 Posts
    Welcome to the site!
    You should post your question in the tech forum. You'll get more responses.
  5. Jimmiee
    Jimmiee New Member 1000 Posts 100 Posts
    Welcome aboard.
  6. bob13
    bob13 New Member 1000 Posts 100 Posts
