Converting 90 Burban to carburetor
Discussion in 'GM Powertrain' started by wildbill5613, Feb 23, 2014.
  1. wildbill5613
    wildbill5613 New Member
    Hi, I recently purchased a very nice 1990 Suburban with a bad motor, I've got a crate engine that came from who knows what but its carbureted with an electric choke, what all do I need to make this conversion? Biggest thing im worried about is the fuel pump and possibly the distributor....thanks ahead for all input
  2. Scott_Anderson
    Scott_Anderson Rockstar 100 Posts
    If the block bolts up to the frame and trans, why not just put the tbi system on it.
  3. wildbill5613
    Well the guy that wants to buy it, wants the carb instead of the tbi, gotta make it complicated haha,
  4. Crawdaddy
    Off the top of my head, you'll need a fuel pressure regulator to bring the fuel pump output down into the acceptable range for carbs. Assuming it's a half-ton, you'll also need a TV cable and bracket assembly for the 700R4 transmission. Otherwise, everything else should transfer over pretty easily.
  5. wildbill5613
    Well I guess the engine is a 355, does this change anything?
  6. Crawdaddy
    So long as it's built off a Chevy Small Block block, nope.
  7. wildbill5613
    Alright got that figured out, now anybody know why coolant smelling/tasting steam would be coming from the vents and from inside the plastic around the where the ac goes into the firewall
  8. Scott_Anderson
    I would guess that you have a leak in the heater core.
  9. wildbill5613
    Well some beach lol, guess I'll get to changing that now, haha, we got this thing, its in literally show room quality condition, and has been sitting for prolly 8 years, we got it out if the barn and you could drive it for about 3 miles and the temp would peg out and it would die, then we broke off all four bolts for the water pump, so we swapped the engine, and now its doing this and it shifts gears up and down constantly, but I think that's just a vacuum issue
  10. Crawdaddy
    The transmission erratically shifting up and down is due to improper TV cable linkage or low ATF fluid. Either way, get that fixed pronto, as the transmission can be destroyed very very quickly like that.
