Cruise Control INOP!!
Discussion in 'General Chevy & GM Tech Questions' started by colemanba, Nov 17, 2008.
  1. colemanba
    colemanba New Member
    :neutral:Hey everyone,
    Just had a quick question. Got an 04 Silverado LS 4.8L and the cruise control does not work. Checked the fuses and looked for cut or frayed wires and found nothing wrong. I only have about 58,000 miles on the truck, so it seems kind of weird for it to just quit working.
    Any suggestions??
  2. JMoney02
    Cruise controls on the lever for the turn signals, they have a small lead of wires that run down the steering column on the under side and connect at the base. There is also a small connector in the cover
    of the lever on the column, check both of those. Sometimes for NO REASON they become loose. You can also use a test light and make sure you have power going down and out to the cruise head, if not then its in the lever and you will need to replace it.
