Cruise control stopped working on my 2007 Silverado - no warranty left
Discussion in 'General Chevy & GM Tech Questions' started by Sportmod5, Oct 28, 2010.
  1. Sportmod5
    Sportmod5 New Member
    Hello Everyone,
    I've got a 2007 Silverado 4wd I just bought 2,000 miles ago and the cruise recently quit working.
    I've checked fuses and can't find anything for the cruise, I've taken the battery loose about 3 times now and it doesn't reset it either.
    Any help in finding my issue would be appreciated.
    Thanks, Mark
  2. murdog94
    Is it a classic or NNBS??? and how many miles are on it??
  3. ChevyFan
    Could be anything from a short in the arm to a control module issue. When did it go out? any codes or other issues?
  4. Loggerhead Mike
    you have a brake switch and cruise switch above your brake pedal. if your tailights work correctly take the brake switch apart and you should see the bad contacts. cheap part or you can clean the contracts and add dialectric grease
    some modles the brake and cruise are built into the same switch. It will throw a code if failed but not illuminate the MIL, get the code checked usually a dead give-away
  5. mmiles
    mmiles New Member
    I had the same problem with my 2008. It was a bad brake light switch. Diagnosis and replacement was something like $125 at the dealership.
  6. Sportmod5
    Thanks guys.
    I'll check out that switch tonight because the brake lights are still working ok.
    The truck has 101,000 miles on it and it's the newer style body so I don't think it's the classic.
