    Join Today ~ It's Free
Cruise control switch
Discussion in 'GM Electrical Tech' started by tomas, Jun 7, 2010.
  1. tomas
    tomas New Member
    Do any of you Techies know of a way to test the cruise control switch on the multifunction stalk. I would like to isolate a problem (not working) on a 98 Sonoma. It recently stopped working and I have tested the fuses. I would like to be able to test the switch before dismantling it. I do have an Ohm meter and know how to use it. I don't think it is a mechanical problem, merely in the switch or wiring. Any help out there?
  2. murdog94
    Youve got me.. I usually check relays etc.. But that is a common failure on these rigs (all GMs with the multi function switch for that matter)
  3. tomas
    tomas New Member
    Well I noiced the high mounted brake light on top of the cab was burned out so I replcaced the two bayonet type bulbs. They still don't work, but, guess what--- the cruise started working again. I knew the brakes and cruise were integrated but go figure! Nice wiring there GM!
  4. Mean_Green_95
    Check the brake light switch. If its acting up then neither the brake lights nor the cruise will work properly.
  5. tomas
    tomas New Member
    Brake lights work, always have, just the high-mounted light was out. I am still going to look into the wiring for that and check the brake-switch.
  6. drwdominance
    drwdominance Rockstar
    what is a brake switch? my cruise just stopped working too. i think it has something to do with my messed up electronic brake control unit.
  7. Mean_Green_95
    It is the switch connected to your brake pedal. It turns on the brake lights when you press the pedal.
  8. drwdominance
    ahh i see. good news is i disconnected the brake control unit and my cruise came back.
