    Join Today ~ It's Free
cruise control
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by TheUnit, Jun 24, 2009.
  1. TheUnit
    TheUnit New Member
    And yet another issue...90 Sub 4wd. Cruise control has never worked since I've owned it. What am I looking for?? Module itself? Servo? Fuse is fine. Possible grounded wire? Cable?
    If you're had similar issues what did you do to correct it?
  2. werty
    werty New Member
    last on e i had to mess with ended up being the blinker handle.f\ thats how yours is run right?
  3. TheUnit
    TheUnit New Member
    indeed it is.
  4. Jimmiee
    Jimmiee New Member 1000 Posts
    Those switches go bad quite frequently. The easiest way to check them is with a scanner. You can see if the switch is working without taking anything apart.
  5. TheUnit
    TheUnit New Member
    Nice. Run down to to parts store and have them just run a quick scan huh? I didnt know that function worked pre-OBD2!
  6. werty
    werty New Member
    ummm..neither didd i?
  7. Jimmiee
    That function won't work with an OBDII code reader like the parts store uses!
    BUT, if you scan it with a real scanner like a Tech II, you will have data as well as codes. :)
  8. werty
    werty New Member
    BUT, if you scan it with a real scanner like a Tech II, you will have data as well as codes.:party:
    good call
    all i got is a odb2 and a paperclip
    ps
    i like it when a "real scanner"is hooked up
    you can watch it run!!!!
  9. TheUnit
    TheUnit New Member
    between a horrid sunburn/tan on my back from last weekend and a lack of motivation, i have not looked in to this yet. i suppose this weekend after installing a new radiator i might try to fix the cruise issue.
  10. Big6ft6
    Big6ft6 New Member
    Hey Unit,
    I have an 89 sub and CANNOT for the life of me find a replacement radiator that fits using the factoring mounting hardware. Where did you get your radiatorand what are the core dimensions?
    Here are mine (just the core)
    19 in high
    28 5/16 wide
    1 5/16 deep
    I just posted about this issue...
