Custom Air Intake Scoop for GMT900 Trucks
Discussion in 'Performance & Fuel' started by Wolfman217, Aug 10, 2013.
  1. dobey
    Please quantify "a lot" and "tad more power" then. You're testing this on a dyno in a controlled environment where ambient air temperature is consistent across the entire run of testing, and no exterior wind affecting the data, right?
  2. Wolfman217
    Wolfman217 Member
    No I am not, to make it like any other scoop, I took the fan off and now it looks legit in my engine compartment! It leads right up the the funnel from the front of the grill. It couldn't of been a more perfect fit.
  3. lonelywolf858
    lonelywolf858 Rockstar 100 Posts
    I'll sub to see how this turns out. I don't see much gain happening but every little bit helps I guess.
  4. vncj96
    get a 160 degree t stat, cooler engine, means less underhood heat means less heatsoak into the air inlet
  5. Holbrook.Jeremy
    Holbrook.Jeremy New Member
    Glad you took the fan out, this was a disaster waiting to happen. The truck pulls more then 200 cfm when idling.
