cv joint hits crossmember
Discussion in 'General Chevy & GM Tech Questions' started by voodoo 350, Jul 30, 2008.
  1. voodoo 350
    voodoo 350 New Member
    I have an 85 k20 with a 6 inch skyjacker lift, front springs and rear add a leaf and blocks. In 4 wheel, and only under some load the front driveshaft c.v. joint at the t-case hits the crossmember. I have added spacers to the crossmember to lessen driveshaft angle, but no dice. I have heard that on some models there is a torsion bar that connects the t-case to the bell housing to reduce movement but my truck doesnot have this part. i have read that you can notch the crossmember but i dont want to cause a weak point by doing so. The truck performs very well even with the banging but i am sure it will lead to some kind of hell down the road. I have searched endlessly and cannot find an answer that makes sense. Any info is much appreciated!!!
  2. voodoo 350
    and all the mounts are brand new with energy suspension inserts
  3. tbplus10
    All the ones I've seen have been notched for clearance. I saw one that had a piece of tube welded on the crossmember farther back to strengthen it.
