Cylinder # 5 sucking
Discussion in 'GM Powertrain' started by somonenew1994, Jul 14, 2010.
  1. somonenew1994
    somonenew1994 Member
    alright i got the truck timed and i had it damn close but it still run like sh!t so i tried changing the spark plugs still no differance i pulled number 5 spark plug and it smoothed right out still ran rough but alot better i put my finger by the hole and it tried sucking my finger in could this by a valve stuck open or what would cause this. i am getting really sick of this truck
    ---------- Post added at 07:49 PM ---------- Previous post was at 07:41 PM ----------
    sorry forgot to add in its a 97 suburban with the 5.7l
  2. somonenew1994
    random mifire code and what do u mean married ? and this motor is soppose to only have about 40,000 on it and what made me get the motor timed was ckp/cmp correlation
  3. TrailLeadr
    TrailLeadr Epic Member 5+ Years 1000 Posts
    A valve stuck open wouldn't allow much suction at the plug hole. If the valve was stuck closed it would.
    I'm sure there's more to this story, but what made you think to pull the #5 plug while the engine was running? Seems kinda random.
  4. Chris Miller
    Might need a bigger spark plug hole. :D
    sn1994, definitely put a compression tester on it. It sounds almost like you've got a busted rocker arm on the intake valve. You might want to pull the valve cover and see.
  5. k.daddy1
    k.daddy1 Rockstar 100 Posts
    Need a compression tester! All of the cylinders will suck during a certain revolution, but you may have a different issue causing the misfires. Those series engines are prone to blown intake gaskets which will cause the misfire codes. Pull all the plugs on the passenger side of the motor and look at those plugs. You'll probably have one that looks a little crusty. Have you had to add any water or anti-freeze lately?
  6. somonenew1994
    alright first thing yeah i would love it if the hole was bigger :great:
    now for the real stuff yes the cap and rotor were just replaced along with new wires and coil icm and crank sensor and no the code for the ckp/cmp is not coming up any more
    now what made me start with number five was when i had it at the shop to get it timed once the timing was right it still ran rough so they looked up cylinder misfires and i am misfiring on 5 (591) times 7 dont remember and 8 dont rermember how many times they misfired. so i pulled the plug to look at it than just for grings and stuff i started it and than it smoothed out the compressing on the cylinder is is 0 and when i put my finger there by the hole it sucked it in and held it there
    after that i did pull off the tappet covers took off the rocker for the intake on five and hooked up air to the cylinder ( the way u hold your vavles up when u take off the springs) and you can hear it coming out the intake no matter what i tried with the vavle
    so now for the new question would my 97 heads bolt up to a 98 to a 2000 motor ok i know they will bolt but will the work i know my old heads a great and i just rplaced the intake on the truck too so they are brand new gaskets in there sorry about the big run on my mind dont let me type right
  7. k.daddy1
    You need a Xanax? Chill dude, your not making no sense! Do you have a compression gauge? Removing the plug and starting it isn't going to tell you anything except when that cylinder is on the intake stroke, compression stroke, or exhaust stroke. You need to verify if you have compression. If you do, then you have another problem. Could be like what was stated in the other post, plugs, cap, button, wires, etc., but could also be anti-freeze fowling the plug, could be the cap you just put on. Post something we can work with.
  8. somonenew1994
    yes i have a compression gauge number 5 is 0 number 7 is at 150 so no there is no compression on the cyclinder
