Dash Noise
Discussion in 'General Chevy & GM Tech Questions' started by glp08, Feb 27, 2009.
  1. glp08
    glp08 New Member
    I have a 2008 Silverado Ext Cab with a 5.3L. When I'm going down the rode at a steady pace between 30 and about 50 mph I get a sound coming from the dash. It sounds like a vibration or rattle. Almost like its a very small ball bearing shaking around in a very small area. Does anyone else get this or know what it is. I'm also wondering if it is a switch or something to tell the convertor to lock up. Driving me nuts:grrrrrr:
  2. RVJ
    RVJ Rockstar 100 Posts
    Try removing the black plastic engine cover, (it snaps into rubber grommets) then go for a ride and see if it's gone. My 08 Sierra did the same thing and it was a wiring loom rattling on the engine cover. I used wire ties to secure everything and the rattle has been gone ever since.
  3. GreenZ71
    GreenZ71 New Member
    I get a rattle in my 99 Seirra that seems to be right in the middle of my dash. Sounds about the same what you have. I will try the same suggestion though.
  4. canislupis69
    I have the same exact noise from the dash of my 08 1500 4x4. I took it to the dealer a while back and of course it would not reproduce the noise while it was there. I am going to try taking off the engine cover also.
  5. lsutoms
    lsutoms Rockstar 100 Posts
    i seem to have this noise that ya'll are talking about in my 09 ext cab... except mine comes more often on my drivers side column it sounds like.... i cant figure out what it is....
  6. Greg84
    Greg84 Rockstar 100 Posts
    The trim around the windshield can make a rattling noise, its really noticeable if you have a bug shield on the truck. A little silicone adhesive under the rubber molding on the sides of the windshield will stop it if thats whats causing it.
  7. mkruluts
    mkruluts New Member
    My truck has a knock sound that seems to come from the dash as well... It only happens in cold weather and I just assumed it was the tubes and hoses under the cold conditions...
  8. cobra2end
    cobra2end Rockstar 100 Posts
    A friend of mine has a 99 gmc and his had the plastic part in front of window that rattled going donw the road. Might be the same thing
  9. Loggerhead Mike
    its pretty common for the front dash trim (the long piece under the windshield w/ the sunload sensor) to rattle. pop it off and put tape around the retainers. you want a "bushing" between the panel and dash
