Daytime running lights
Discussion in 'Chevy Express Forum (GMC Savana)' started by vannooch, Nov 2, 2013.
  1. vannooch
    vannooch Rockstar
    The daytime running lights have started flickering on my 01 Savana SLT. Does anyone know what switch controls these? They will come on while the high beams are on as well. I am not opposed to disconnecting them if it doesn't affect anything else.
  2. tsbrewers
    tsbrewers Member
    that is kind of a tough one. I would check the DRL module and see if the wiring harness is connected well and clean. I think this is a picture of where it is located, it is tough to make out exactly where this is on the vehicle (left side?) but you might recognize it more on your own van. If not that, possibly a bad switch inside the van, or bad relay possibly?
  3. Dueck
    Dueck Member
    Is it only your DRL's or is it all your lights?
  4. vannooch
    vannooch Rockstar
    DRL's only. If I turn on my low beams it stops, if I switch to high beams it will flicker the DRL's while they are on. They don't flicker consistently.
