Dex Cool Information
Discussion in 'How-to Guides' started by Dr_Zero, Mar 18, 2009.
  1. Dr_Zero
    I dont know if you everyone here is familiar with the DEX COOL coolant and the issues attributed to it so I have compiled a set of links and info about it (and how to rid yourself of this mess)
    Rust in Cooling System, Heater Inoperative, Blows Cold Air, Engine Overheats (Flush Cooling System) #99-06-02-012D - (Apr 9, 2002)
    http://members.shaw.ca/betterthanyoutoo/dexcoolflush.htm
    http://www.sancarlosradiator.com/dex-cool.htm
    http://www.imcool.com/articles/antifreeze-coolant/dexcool-macs2001.php
    http://www.imcool.com/articles/antifreeze-coolant/GMdocs/dexcool2007-5.7L-IMG.php
    DEX-COOL 2007, Part 1a: 5.7L V8 Engine Sludge and Gasket Change
    PICS!
    http://www.sancarlosradiator.com/dex-cool_pics.htm
    http://www.motor.com/article.asp?article_ID=816
    COOLANT CONFUSION: It's Not Easy Being Green . . . or Yellow or Orange or . .
    All DexCool-approved coolants to date use two organic acid rust/corrosion inhibitors, one called sebacate, the other called 2-EHA (which stands for 2-ethylhexanoic acid). These organic acids are very stable and last a long time, although they take thousands of miles to become fully effective in protecting coolant passages.
    The inhibitor 2-EHA works well in hard water and is more effective than sebacate at lower pH levels (when the coolant moves from the alkaline end toward the acid side), particularly for cast iron. Well, GM has a number of cast-iron engines. When there's a low coolant level in the coolant passages, the exposed cast iron rusts. Apparently, that rust is washed away later by flowing coolant, and is deposited in the heat exchangers. It eventually produces the rust powder problems that have been so widely observed (see MOTOR's August 2002 issue at www.motor.com). Why does the coolant level in these engines drop? The original radiator cap design was blamed for some of the issue, but there probably are a number of causes, including owner neglect and normal seepage. However, the rust powder issue is not a problem that was observed with the previously used conventional American coolant.
    The inhibitor 2-EHA poses another issue: It's a plasticizer (softens plastic), so it has been blamed for coolant passage gasket leakage. Softening (and the resulting distortion) was reported by Ford, which encountered gasket leakage problems when it tested a DexCool-type formula on its V8 engines. Ford also saw similar issues with other gasket materials. That killed the OAT coolant idea for Ford, which had used a DexCool-like coolant in the '99 Cougar V6.
    Could that inhibitor be responsible for the intake manifold coolant gasket leakage on GM 60° V6 engines? Or is there some other service issue involved? (After all, GM isn't the only one with coolant gasket leakage problems.) The experts are still working on it.
    How to Flush by Advance Auto step by step
    http://www.advanceautoparts.com/english/youcan/asp/ccr/ccr20010501rm.asp
  2. TRPLXL2
    Wow I just learned something else today! I have been using the Prestone 50/50 blend, you know the stuff that doesn't matter what color is already in the vehicle. Well the other day I was adding coolant to my S-10 and I noticed what looked like brown mold in the coolant tank, I didn't think anything of it but it sure looks like the one picture that was in one of your links that you posted. I just hope I didn't mess up the radiator too, that's all I need now! Thanks for posting yet more helpful info,................AMY:great:
  3. Dr_Zero
    You are welcome!
    About the brown gunk well I would get the system flushed or get one of the prestone kits at least and run some of the heavy cleaning kind. Oh and put in some good ole green anti freeze not the 50/50 mix kind you are paying for 50% plain ole water (the 50/50 is ok to top off but you can make your own cheaper)
    Some shops have a machine that can vacuum out the system and flush out the block I have seen it done on one ride it looked like oatmeal coming out of there :shocked:
    The wifes truck we flushed it but it was too late the radiator was plugged, so I had it rodded out but found out later for the cost of the cleaning I could have got a NEW radiator.
    I got a new 2 row vs 1 row for around $100 shipped to the house!!!
  4. MWright936
    Thanks for the write-up! Great information!!
  5. CARGUY1280
    CARGUY1280 New Member
    This explains what Has happenend to my moms Monte 2 years in a row. Last 2 winters it starts blowing cold all the sudden. It was flushed last year and then still did it this winter too. My truck now needs flushed out, good thing I can get free coolant from work. We have blue long life in our cars but its the same as the green stuff. Saves a ton-o-money..
  6. Dr_Zero
    The potential role of DEX-COOL® in GM 3800 lower intake manifold gasket failures
    http://www.dex-cool.net/
    (Go to link to see article with pics its worth it)
    visit www.pontiacbonnevilleclub.com for more information from our very experienced team of gearheads
    Introduction
    Before you read further, let me introduce myself. I'm not an automotive specialist or professional. I'm an enthusiast, or hobbyist. My interests are primarily focused on the Buick 3800 V6's commonly found in Pontiac Bonnevilles, various Buicks, Chevrolets, and Oldsmobiles. I'm also an Administrator on www.pontiacbonnevilleclub.com, an internet Forum for Pontiac Bonneville owners. Over the 6+ years I've been there and the forum it replaced, we have endured countless topics, gasket failures, and blown engines. Our Gearheads on the forum have diligently fought the battles and we've learned a lot about how to help prevent the problems, but never really FULLY understood the root cause. I, among others, have spent countless hours reading on the internet about all the lawsuits, reports, claims, and rumors. I decided to take it a step further using some good analytical approaches, and some nice tools available to me at work. I design and build custom research and development laser systems for Hewlett Packard.
    This page is primarily focused on the failure of lower intake manifold gaskets in GM 3800 motors. These are pushrod V6 engines with cast iron blocks and cylinder heads. The motors are renowned for being 'bullet-proof'. Some are supercharged from the factory, and many are pushed to the limits of performance by other enthusiasts. While other GM engines have had the same problems, I'm only going to briefly touch on them in this report. I've long suspected DEX as being the primary culprit in early lower intake manifold (LIM) gasket failures, but to this date, nobody has proven it. I won't prove it in this report either, but the grim reaper may be pointing a little more emphatically in that direction by the time he finishes reading this.
    Goals
    The goals of this report are simple:
    1. To attempt to dispel the rumors about some of the possible causes of early gasket failure in these engines.
    2. To attempt to reveal all the possible variables that may play a role in these failures.
    3. To invite yet more controversy and discussion on the topic, and perhaps encourage someone to investigate further.
    The investigation starts
    I have 2 sets of gaskets to compare that are good candidates for this report. The first set was removed from one of my own cars, a 1995 Pontiac Bonneville SE, with the supercharged engine as a factory option. The gaskets are OEM as installed from the factory and were removed at 125,000 miles as routine maintenance, the car was not originally 'equipped' with DEX (had the old-school green glycol stuff), and to the best of my knowledge never slurped the DEX at any time in it's life (the original owner's son-in-law is a Service Manager at a GM dealer, and knows better.....I bought the car from them). The second set is from a 1998 Pontiac Bonneville SE, and these gaskets were installed sometime after 2002 when the upper intake manifold was replaced due to a presumed failure. The UIM has a manufacturer's date of 2002, and the Gaskets were manufactured in 2001. 30k to 40k are the estimated number of miles that these gaskets were in the car. It's unknown if the car had a coolant flush at the time of gasket and UIM install, but it is presumed (the work happened at a dealer, and GM dealers know about DEX's ability to turn acidic over time).
    Both gaskets are known to be made of the same materials. The main carrier is Nylon66. It was invented in 1935 by an organic chemist named Wallace Carothers who worked for DuPont. The strength and durability of the material is more a matter of HOW it is processed than what it actually is made of. Liquid polymers are blown through very small nozzles, and allowed to solidify, creating a very strong inter-woven mesh of fibers thinner than a human hair. This is very important, and will be explained later in this page. His patent was granted in 1937, and a short time later, depression caused him to commit suicide by drinking cyanide. Ironic to say the least, but he had no clue what role General Motors would play in this story years later. More information on Nylon can be found here.
    These two sets of gaskets were chosen because they represent the 'norm' in lower intake manifold gaskets in GM 3800 engines. Series 1 gaskets tend to last much longer than Series 2 gaskets, and the transition year between these two engines were within one year of the introduction of DEX. An important note to be made is that there ARE exceptions to this 'norm', but we'll address that later in the page.
    Basic Properties of Nylon66
    Nylon66 melts at temperatures from 255 to 265 degrees C, or 491 to 509 degrees F. This is important, so remember it. Tensile strength is 13,700psi, and even higher in 50% humidity, at 17,000psi. This is also important. Yet another property we'll care about later is it's elongation at the break point. This is described in simple terms how much it stretches before it breaks. Dry rating is 15-80%, and at 50% humidity, it runs 150-300% (at the break when stressed). This might be important information in an application where it's subjected to water. Nylon 66 Properties
    Nylon66's acid resistance is a more difficult story. It boils down to what kind of acid we're talking about. As shown on this page, Nylon66 isn't shown in the 'Acid Resistant' column. While it resists SOME acids, it's not considered 'acid resistant'. Taken from here, the data shows the resistance properties of Nylon66 to several common acids is poor. We'll talk about that later. In the meantime, try this link out for a backup of the acid resistance properties.
    We're concentrating for now on Nylon66 as the carrier (main frame of the gasket) rather than the silicone-based rubber tracings of the gasket, as it's very obvious in a failed gasket that the Nylon, for whatever reason, just plain 'let go'.
    Properties of DEX-cool
    This page has a really good description of what DEX really is. DEX uses OAT, or organic acid technology to extend the service life of the product. But one of the primary ingredients is known to soften plastics (or polymers.......sound familiar?) if not kept 'in balance'. One of these 'imbalances' is air introduced into the system. This is typically from very small leaks in the cooling system that most car owners wouldn't be aware of. These leaks, or any other failures, cause DEX to turn acidic over time. Properly maintained, in a perfect or near-perfect system, this SHOULD never happen. This is why we see some cases of DEX'ed LIM gaskets achieving longer lifetimes. They lived in a perfect world. Unfortunately, most of our cars aren't nearly as perfect under the hood as most of us would like to believe.
    Let's get down to it
    Let's meet the victims:
    On the left is the DEX 30-40k LIM gaskets....................................................On the right, the 125k non-DEX gaskets
    From this picture, we can all see that something just isn't right with the gaskets on the left. But it's pretty typical. Let's take a closer look. We'll call them DEX and NON-DEX from now on.
  7. Dr_Zero
    DEX:
    NON-DEX:
    Overlaid showing low-mileage DEX on the left, and high-mileage NON-DEX on the right:
    It's probably safe to say that for the purposes of this comparison, there's no reason to look any closer at the NON-DEX gaskets, but we will briefly do so later. You can be assured that the problems we find here with the DEX gaskets do not even remotely exist in the NON-DEX gaskets in this comparison. Again, there are exceptions out there, but they are isolated instances. DEX-exposed gaskets typically start showing problems at about 30-50k miles, and NON-DEX at 100-125k miles. Keep in mind, the gaskets on my OTHER Bonneville (1993 SSEi) looked just as good as these NON-DEX gaskets out of my SE at 85,000 miles.
    So off to the microscope I went, but I'd already seen what I was after. The DEX gasket had some interesting characteristics. I'd already concluded this some months earlier:
    ______________________________________________________________________________________________________________________
    This was about 6 months ago, before I really started digging into the root causes and the effects of the 'environment' on certain type of materials in question. It looks pretty obvious that the DEX coolant wicked around in the path I showed in the picture above, but we still have to rule out over-torquing the gaskets, and the effects of heat. For now, let's get on to looking even closer at the failed DEX gaskets.
    This is a 50x magnification (Nikon microscope with 50x objective lens and incandescent top-lighting) view of the INSIDE face of the coolant port that normally flows coolant (the other port is 'blind' and while exposed to DEX, doesn't actually flow):
    See the exposed fibers? This isn't normal Nylon66. It's been altered by something. The NON-DEX gasket didn't look anything like this under high magnification. Let's look at a lower-magnification view and I'll explain more.
    This is a 5X magnification view of the same coolant port. This is shot from the 'LIM view', as if the camera were placed in the lifter valley instead of the lower intake manifold, and the picture was taken looking towards the gasket with the cylinder head behind it:
    Coolant port..............eroded Nylon66.......................non-eroded Nylon66..............silicone seal
    Notice the eroded portion showing exposed fibers? This is the portion of the Nylon66 gasket that is exposed to the DEX flow path through the gasket port, manifold, and engine. The other port wasn't as bad. Let's call it half as much fiber exposure. But the other port is BLIND. It has no flow. The NON-DEX gasket under the same magnification looks like the non-eroded portion of the picture above (vertical band under the '1' of '1/1000'). Why?
    Let's rule some stuff out
    Other explanations have been offered in the past in order to try to make sense of the failures we see. Heat, over-torquing, and gasket materials. We'll take them one at a time, but not in that order.
    1. Gasket Materials. Both gasket 'generations' are made of the same carrier material. Nylon66. Since that is the mechanical failure we see in the pictures above, that's the one we care about. It's the same for both gasket sets.
    2. Over-torquing would show failures around the holes for the LIM bolts in the gaskets. We don't see that, and we know the compressive strength of Nylon is quite high. The failed areas are nowhere near these potentially over-torqued holes.
    3. Heat. This can't be a factor based on the known properties of Nylon66. Regardless of those properties, if temperature were the issue, the gasket carrier would fail in the 'dead' areas of the gasket, and not in the areas we see the failure. The average maximum coolant temperature in the coolant ports is from 200-220 degrees Fahrenheit. The intake ports see COOLER temperatures due to the intake air charge flowing through them. In addition, the NON-DEX gasket shown here is from a supercharged engine that produces higher intake air temperatures due to compression before it gets to the gasket.
    So now let's talk about gasket re-designs. GM 3100 and 3400 engines also ran DEX. Those gaskets are known to have gone through design changes at the same time as the first redesign of the 3800 gaskets. The material around the coolant ports (flexible something or other) wrapped around the nylon so that the coolant would not be in contact with the Nylon carrier. The 3100 and 3400 engines never saw the latest revision, which replaced the Nylon carrier with aluminum. Why? My theory is that GM knew the dates that those engines would cease production, and that the 3800 would continue through 2008 or 2009. In addition, the 3100 and 3400 engines are used in the smaller less-costly cars, while the 3800 is typically used in the 'flagship' models for each GM division. That's called good business sense.
    Conclusions
    My personal theories based on what I've shared with you in this report, is that ACIDIC EROSION breaks down the Nylon carrier material, and wicks around the silicone rubber seal until it starts breaking down the carrier around the intake ports. This is based on the known properties of Nylon66 and the typical failures I've personally seen in 5 years as an Administrator on an automotive internet forum. The fact that the 'dead' coolant port doesn't erode as badly is testament to the fact that the acid needs 'flow' or must be refreshed in order to start eroding the nylon. It may also be true that the sludge that typically builds up in the dead coolant port protects the nylon carrier from further erosion.
    GM had choice between several corrosion inhibiting acids in their formulation of DEX, and probably didn't choose wisely. Aftermarket OAT type antifreeze products use other types of OAT inhibitors that are not known for softening plastics. This may have been pure dumb luck based on the fact that GM had covered themselves with a patent and a proprietary formula, or it may be that the new competitors in the market knew the dangers and chose more wisely.
    My personal suggestion is that anyone that currently has DEX in their car should change the LIM gaskets to the most recent design for their vehicle, and switch to Prestone Long-Life "mixes with any" (not DEX-compatible) antifreeze, which uses a different corrosion inhibitor that is NOT known to soften plastics. There are rumors and theories around the internet that mixing the old glycol-based green coolant and DEX produces undesirable results like sludge, crystallization around gasket materials, and other scary things. I don't suggest replacing the coolant in a DEX car with the 'green' old-school glycol based coolant for these reasons. In fact, Havoline manufactures the 'new' DEX formula for GM, and they clearly warn consumers not to mix more than 10% conventional coolant (green) with DEX:
    http://www.havoline.com/products/na/antifreeze_01.html
    "Chevron recommends that this product not be diluted by more than 10% with conventional coolants."
    If DEX isn't a problem, why did GM re-design all these gaskets (twice for some of them) AND re-formulate DEX? Is it coincidence?
    You can form your own conclusions from this page, but I would also encourage you to investigate it for yourself. Perhaps someday we'll all know the answers without any doubt.
    The information and opinions are my personal thoughts.
    I am in no way affiliated with GM, DEX-Cool, or any other commercial venture.
    www.zillamotorsports.com
    Thanks to Don Blackwell and John Wikoff for their contributions to this page
    Contributions were made by the members of ww
  8. justaphase44
    justaphase44 Rockstar
    I had a 04 silverado that had to have the intake gasket replaced because of leaking coolant back in 05. I ran stock dex-cool in it for 3 years until I sold it. But... one day I was checking my oil and noticed some coolant around of the intake by piston #2. And it only had about 20k miles on it, so I took it to the dealer and they gave me a tahoe for a week. Once I got it back didn't notice a problem afterwards. Everything was bone stock except for the stereo system. Don't know if that helps but did have a bad experience with either the dex-cool or just a bad gaskett.
  9. pontiacGTP123
    pontiacGTP123 Rockstar 100 Posts
    thanks for the info
  10. We experienced this issue several years ago in a 98 Montana with a 3800. This was before everyone seemed to be aware of it. Fortunately I was able to find a bunch of info online about people having the same problem and GM having to replace the gaskets (at the very least).
    I accumulated all of the info I could, took the problem child to the dealer and asked for a solution. Their first response was to say they weren't aware of any problems with Dex Cool. It was then that I laid my stack of info, claims and research on the counter and suggested they educate themselves. Fortunately we didn't have to threaten or push too hard to get them to fix the problem on THEIR dime. Even after the replacement they filled her back up with Dex Cool.
    I'm glad I ran across this thread because it's reminded me of the problems we had and the reason I need to swap that stuff out of my recently acquired 04 2500HD.
