Diablo Sport Tuner
Discussion in 'GM Powertrain' started by NVR_LFT, May 25, 2009.
  1. NVR_LFT
    NVR_LFT New Member
    I have an 08 tahoe with the 5.3. I am running a spectre cold air intake and a corsa exhaust. I also got a diablo tuner and have tweaked with it a bit. I added 3 degrees of timing and pulled 3% on the fuel. Things tacks out hard on the big end between 4000-5500 RPM, seems to be lacking in the mid range. Any suggestions on what kind of tune to run?
  2. silveradotrailblazer
    Diablosport tuner
    What fuel octane did you tune for? How did you determan to take out 3% fuel? I believe with your year tuner you can adjust timing in three differnat rpm ranges. Did you tune any rpm range other than 4,000 to 7,000? When you said you took 3% fuel out, are you refering to Long Term Fuel Trims?
