Differential Oil Change After Initial Break-in
Discussion in '1st Synthetics' started by 1st Synthetics, May 19, 2009.
  1. 1st Synthetics
    To define when most wear occurs in differentials, what
    internal components are involved and how to get the
    optimum differential life from your vehicle.
    All components in a vehicle are equally important. If
    your engine fails, you become stranded. However,
    you become just as stranded if the differential fails.
    Most motorists are unaware of the lubricants other
    than motor oil that require changing in their vehicles.
    According to one quick lube oil change company, only
    2% of its customers change their gear lube. Differential
    gear lube is one of the oils that should be changed
    in order to optimize the gear and bearing life, but it is
    often overlooked or changed only when failure occurs.
    Full story in PDF
